Bronze Member Username: Kille
Post Number: 35 Registered: Feb-05
Posted on anyone know why the last ecm has killed my remote and power switch on my receiver? |
Bronze Member Username: Iamdrumming
Post Number: 81 Registered: Aug-06
Posted on An ecm can not kill a remote. |
New member Username: Boston410
Post Number: 3 Registered: Jan-08
Posted on did the same to my remote, had to shut off power on back of unit and turn it back on, and then when unit came back on, bev was down |
Gold Member Username: Kirankumar
Kenya
Post Number: 1118 Registered: Oct-07
Posted on try bin 162 |
Bronze Member Username: Molari
Post Number: 45 Registered: Oct-06
Posted on If you are looking for BEV fix...Bin 162 will solve your problems...mine works great with all channels comming in freat. ;) |
Post Number: 36 Registered: Feb-05
Posted on tried new keys, but froze at the end, can't even power down fron the front.......weird |
Post Number: 48 Registered: Oct-06
Posted on I am confirming CS 5000 Bin 162 works perfect for Bev. Even other people in CS forums confirm what i am saying here. Just upgrade from Bin 157 to Bin 162 and everything will work ok. Regards |
Bronze Member Username: Amitm21
Post Number: 11 Registered: Jun-06
Posted on i'll try that when i get a chance, i have 1.57 right now as well, thanks AGAIN molari |
Post Number: 16 Registered: Jun-06
Posted on it works...thanx |
Bronze Member Username: Tekomi_elhoyo
Post Number: 45 Registered: Jun-06
Posted on The box is possesed. Do an exorcism a report back. |
