Denon 2802 help
Just got the 2802 and have it hooked up to a Denon DVD player and a Def Tech system. The problem I have is the subwoofer won't work in Dolby Digital or DTS modes unless I set it to stereo or direct in which case the center channel won't work. Any suggestions!!!?? I'm using a digital coax cable by the way.
Jason DeWilde
Nevermind, had the fronts/center set to large when they should've been small. All is good.
