Username: Javjla Post Number: 1 Registered: Jan-08
Sunday, January 27, 2008 - 19:28 GMT Guys, I am not getting any indian channels with the new Pansat Bin for DN. Kindly help.
Username: The_coders Post Number: 190 Registered: Jan-08
Sunday, January 27, 2008 - 19:37 GMT same here , no cowboy channels either
Username: Dude123 Post Number: 1963 Registered: Jul-06
Sunday, January 27, 2008 - 19:46 GMT Which pansat receiver do you have? Which bin are you using? what satellites are you scanning? answer to these questions would be nice....
Username: Dude123 Post Number: 1964 Registered: Jul-06
Sunday, January 27, 2008 - 19:47 GMT B3V or DN? All pansats should be up for B3V and DN....They released the latest file yesterday
Username: Javjla Post Number: 2 Registered: Jan-08
Sunday, January 27, 2008 - 19:55 GMT Hello The one Following are the answers to your Questions- I am using Pansat 3500SD. 'X-05BL_080126_361_api_nocard(test)'is the BIN that I am using. I use to get all the indian channels in ECHO 3/Ku Satellite and now they are not coming. This issue is related to DN. Kindly help.
Username: Imars99 BRAMPTON,
ONT
CANADA
Post Number: 44 Registered: Aug-06
Sunday, January 27, 2008 - 19:57 GMT Delete all chennels and do blind scan.
Username: Javjla Post Number: 3 Registered: Jan-08
Sunday, January 27, 2008 - 20:32 GMT I did the blind scan and I am still not able to get Indian channels. Kindly help.
Username: Dude123 Post Number: 1965 Registered: Jul-06
Sunday, January 27, 2008 - 20:57 GMT so you dont see the channels in your list or you see some kind of a message when you try to go to those channels?
Username: Javjla Post Number: 4 Registered: Jan-08
Sunday, January 27, 2008 - 21:09 GMT I see the channels in my list as I use to before. But these channels are not working anymore. I get message as 'No Signal' or 'scrambled channel'. Kinldy help.
Username: Koko_wawa Post Number: 203 Registered: Aug-07
Sunday, January 27, 2008 - 21:21 GMT If you want to watch Indian channels you have to go to India to see them all
Username: Dude123 Post Number: 1966 Registered: Jul-06
Sunday, January 27, 2008 - 21:29 GMT did you try turning your box OFF from the back and then ON after a minute or so?
Username: Javjla Post Number: 5 Registered: Jan-08
Sunday, January 27, 2008 - 21:39 GMT CAN YOU MIND YOUR WORK AND DONT BOTHER karkour kaka.
Username: Javjla Post Number: 6 Registered: Jan-08
Sunday, January 27, 2008 - 21:48 GMT Hello The one I did try that and no result. Kinldy help
Username: Dude123 Post Number: 1967 Registered: Jul-06
Sunday, January 27, 2008 - 21:55 GMT the only thing I can suggest you is that try loading the bin file again and blind scan because 361 is the latest fix for B3V and D!SH....
Username: Koko_wawa Post Number: 204 Registered: Aug-07
Sunday, January 27, 2008 - 21:58 GMT my friends there is an new ECM running in the stream right now and expect coplete bloackade soooon. This explains your problem with indian channels and the dark screen that will follow soon.DN will be down sooon
Username: Dude123 Post Number: 1968 Registered: Jul-06
Sunday, January 27, 2008 - 22:04 GMT kaka Dish is currently working with no problems...I am watching it right now. And it should work on 3500 as it is on 2700
