Does anybody know if there is a bin file for pansat 2700a? I tried bin 243 and 244 but it doesn't work. Any body which one is working right now? It is appreciated, thanks.
you may need to flip the switch in the back of the box a couple of times to "power cycle" the unit. i had a little trouble getting the keys to roll but this fixed my situation. the bin 245 is a bev fix so bin 244 should work for you but 245 wouldn't hurt either.
