Sv4000 stuck "o"
Username: Lomna
Post Number: 89
My sv4k stuck on "o".Won,t show any channel number.All I see "o" Won,t let me do any thing with that.Connection between tv and sv4000 are correct.Tv is black and snowy.When I turn off the unit it start rebooting and end up with "o" on the little screen. Please help. I thank you very much.
Username: Kirankumar
Kenya
Post Number: 1106
devin,
did you load any bins on it recently?
Username: Lomna
Post Number: 90
African..first of all thanks.. I did load bin this morning (196) after loading I scan nimiq1,3. It scaned nicely. I even pressed Ok to save it. But in reality it never saved for me.There was no saved channel.It not even saved satelite for me. So I have to repeat this. During this process it got messed up. Tv got snowy. But tv was showing the actions of the unit even with snowy screen.First I thought may be connection between them got loose . but that was not the case.Then I turned the power off couple times. At this time the unit start showing (little screen where we see channel numbers)"reboot""12.00" "E' It never stop doing that since morning. I tried to press menu from the remote. There is no communication between them.Right now it shows a "o". If I turned the power off now it repeat "Reboot" "12.00" and "E" and it will end with "o" instead of channel number.I,m totally helpless.No clue. Please give me some help. I will highly thankful >>>..
Username: Anai
TX United States
Post Number: 207
turn it off from the rear, for 5 minutes, that should fix it. it worked for me
Username: Lomna
Post Number: 91
Ana .. thank you but I tried that.
Username: Lomna
Post Number: 93
Thanks every one for helping me. I fixed it. Thanks again.
