Username: Smartboyveer247 Post Number: 1 Registered: Jan-08
Sunday, January 27, 2008 - 18:01 GMT I am new to all of this and can someone please help me find 82W, what do I need to do. thanks I have a pansat 2700a
Username: Kirankumar Kenya
Post Number: 1134 Registered: Oct-07
Sunday, January 27, 2008 - 18:03 GMT is your dish aligned to 82W ?
Username: Smartboyveer247 Post Number: 2 Registered: Jan-08
Sunday, January 27, 2008 - 18:04 GMT no its aligned to 61W
Post Number: 1135 Registered: Oct-07
Sunday, January 27, 2008 - 18:07 GMT you need to align your dish to 82w first. go to www.dishpointer.com
Post Number: 1136 Registered: Oct-07
Sunday, January 27, 2008 - 18:11 GMT let me know if you need any more help
Username: Smartboyveer247 Post Number: 3 Registered: Jan-08
Sunday, January 27, 2008 - 18:12 GMT What is this? what do I need? Dish Setup Data Elevation:38.5° Azimuth (true): 196.5° Azimuth (magn.): 212.3° LNB skew: 11.9°
Post Number: 1137 Registered: Oct-07
Sunday, January 27, 2008 - 18:15 GMT your dish needs to be adjusted to those settings so the dish would point at 82w satellite. if you are not good with this kind of stuff you might need an installer come and move the dish for you
Username: Smartboyveer247 Post Number: 4 Registered: Jan-08
Sunday, January 27, 2008 - 18:16 GMT ya but I live in USA,so those are the angles that i need to move the dish?
Post Number: 1138 Registered: Oct-07
Sunday, January 27, 2008 - 18:18 GMT yes. tell me why want 82 w also when you move your dish you will lose 61.5 which carries international channels,is that what you want?
Username: Smartboyveer247 Post Number: 6 Registered: Jan-08
Sunday, January 27, 2008 - 18:25 GMT i have 2 sat dishes
Post Number: 1139 Registered: Oct-07
Sunday, January 27, 2008 - 18:26 GMT so i guess you have 61.5 on one dish and 119 and 110 on the second dish right
Username: Smartboyveer247 Post Number: 7 Registered: Jan-08
Sunday, January 27, 2008 - 18:29 GMT no my friend just moved and he gave me his dish, i have one pointed to 61.5 and i want the other pointed to 82W
Post Number: 1140 Registered: Oct-07
Sunday, January 27, 2008 - 18:33 GMT that is good, you will need to install that second dish as per dishpointer instructions,then you will need a switch,so you will have 2 cables coming from 2 sats to switch and 1 cable from switch to receiver
Post Number: 1141 Registered: Oct-07
Sunday, January 27, 2008 - 18:35 GMT you will need a DisEqC switch
Username: Smartboyveer247 Post Number: 9 Registered: Jan-08
Sunday, January 27, 2008 - 18:35 GMT ya i already have a switch i think its called a diseqc switch, this is what that site gave me Elevation:38.5° Azimuth (true): 196.5° Azimuth (magn.): 212.3° LNB skew: 11.9° what so i do with it? how do i know which way to turn the dish?
Post Number: 1142 Registered: Oct-07
Sunday, January 27, 2008 - 18:37 GMT do you have a signal meter?
Username: Smartboyveer247 Post Number: 11 Registered: Jan-08
Sunday, January 27, 2008 - 18:39 GMT no
Post Number: 1143 Registered: Oct-07
Sunday, January 27, 2008 - 18:44 GMT ok first you need to install your pole,this should be plumb (straight up)then on the dish adjust your elevation,there are markers there.then you will have to guess ,you should get 82 w if you point it to the right of your 61.5 and keep on moving it slowly until you lock in.it will take a lot of time
Username: Smartboyveer247 Post Number: 12 Registered: Jan-08
Sunday, January 27, 2008 - 18:46 GMT see i got 61W easily by using the dishnet receiver,you go to dish pointer and when you pick up the angle the thing goes green and when you dont have the angle the thing goes red, is there anything like that on a FTA receiver?
Post Number: 1144 Registered: Oct-07
Sunday, January 27, 2008 - 18:50 GMT exactly, you got it,and make sure you see 82w on the top right hand corner
Username: Smartboyveer247 Post Number: 13 Registered: Jan-08
Sunday, January 27, 2008 - 18:54 GMT no i am asking it there sometihng like that on the pansat or nfusion?
Post Number: 1145 Registered: Oct-07
Sunday, January 27, 2008 - 18:57 GMT it is on all fta receivers yes
Username: Smartboyveer247 Post Number: 14 Registered: Jan-08
Sunday, January 27, 2008 - 19:00 GMT ok thanks a lot man, what receivers do you have?
Post Number: 1146 Registered: Oct-07
Sunday, January 27, 2008 - 19:03 GMT i have c00lsat 5000 6000 7000, if you follow my instructions you will be ok,if you have any more problems,i am at www.crazyfta i can help you there.good luck
Username: Dimwitt Post Number: 385 Registered: Aug-06
Sunday, January 27, 2008 - 19:03 GMT use the quality meter in the antenna setup, for locking onto a sat. install dish and diseqc switch , do antenna settings for 82 with proper diseqc port and lnb type selected. use dishpointer.com , setup the google map for your dish location , aim as shown and adjust elevation till you get good quality
Username: Smartboyveer247 Post Number: 15 Registered: Jan-08
Sunday, January 27, 2008 - 19:08 GMT ok thanks a lot tooter and african
Username: Madflea168 Post Number: 153 Registered: Jan-08
Monday, January 28, 2008 - 06:32 GMT African, I have a dtv 3 lnb sitting on my roof, do you know if the lnb would work on bev?
Username: Warbe Post Number: 1 Registered: Feb-06
Tuesday, January 29, 2008 - 02:20 GMT you can use your old dish recevier to find the signal from a bev sat(82 or 91)
