GeoNews-AagTV Frequencies for 118
Username: Vittu
Post Number: 114
Username: Saqeeb9000
Post Number: 1819
modulation qsk.. what is that..
Username: Lolol
Post Number: 241
how about for 148??? what TPs would they be on 148 (echo 1.2)?
Username: Vittu
Post Number: 117
lolol. DO a Powerscan and look for channel 902-903. Sorry I don't have a bird pointing to 148
Username: Vittu
Post Number: 119
To the best of my knowledge ( I could be wrong)
QPSK=Normal Dish/Bev Channels
8PSK=BEV HD Channels MPEG2??
Turbo-8PSK= Dish .264 HD (Mpeg4)
Post Number: 1820
vittu what kind or rec do you have..
what kind of lnb?
whats a difference b.w circular and linear lnb?
i have 119 dish on my nfusion rec.. and i tried to scan 118.8 i am getting few channels but i only want agg tv..
i am not sure if i have circular lnb or 30inch dish ? how to check?
Username: Vittu
Post Number: 120
Sada, I have Superdish with 118/119 repoint kit. Currently I am getting 110/118/119/129 with it. I am not using FTA lnbs. As for my system, I have Dish 510 w/rom102 and a Skywalker-1 hooked up to my PC to get HD from Dish and of course using DVB Dream which is the only software that will let you get H.264 channels.
Check your lnb frequecy. I am sure this is why you aren't getting channels of 118.
118.75'w anik F3 = circular lnb, standard = 10750
119'w echo 7 = circular lnb standard = 11250
