Stripped terminal screws
Username: Jtown
Team Revolution, Texas
Post Number: 1809
hey guys I just got a used amp in the mail, it's got a ton of stripped screws, from the terminal screws to the screws that hold the heatsink together. plus it's missing a few.
can I get the replacement screws at home depot, or lowes, or even radioshack?
thanks for the help
Username: Nd4spd18
Northwest PA
Post Number: 5825
Hardware store should have what you need....... pick up a stripped screw remover if ya don't have one also. You may want to take the amp with you so you can try different screws and find out what thread you need.........
Username: Jtown
Post Number: 1811
well I pulled the screws out, they weren't totally stripped...I was just gonna take em up there and compare em to the screws at the hardware store.
Username: Nd4spd18
Northwest PA
Post Number: 5829
Oh, well then you can just do that
Username: Van_man
Boston South, MA
Post Number: 3315
if your replacing them, consider allen head. Makes it look meaner.
Username: Jtown
Post Number: 1820
what do the allen heads look like Marc? like for an allen wrench?
hey M.S., if my amp is rated at 3x40(120amps), would a 100amp power fuse work just fine or should I get something smaller/bigger?
Username: Nd4spd18
Northwest PA
Post Number: 5848
What gauge wire
Username: Jtown
Post Number: 1825
right now...4 guage w/ 100amp fuse. was thinking of doing 1/0 in the near future, when I get the money
Username: Nd4spd18
Northwest PA
Post Number: 5856
The amplifier is irrelevant, the fuse is based on the wire gauge. 125 amp is the ideal fuse for 4 gauge wire.
Since your amp can draw 120 amp, you need 120-125 amp fuse.
Username: Nd4spd18
Northwest PA
Post Number: 5857
BTW do NOT put a fuse bigger than 125 amp in 4 gauge wire. That is the maximum.
Username: Jtown
Post Number: 1828
Thanks M.S., I should be using that size fuse no matter what then, for 4 gauge, right?
if the fuse is to small, then technically is my amp not putting out the rec. specs with just a 100amp fuse on it?
Username: Jtown
Post Number: 1830
bump
Username: Somedonniedude
Illinois United States
Post Number: 830
It will just blow the fuse when you crank it if you use the 100. It wont like cap the amp from putting out more power, the fuse will just overload and blow.
You can prolly run it with that fuse until you get a bigger one. I ran a 60 amp fuse to my amp with 80's (4ga too) and it took 2 months to go out.
Username: Jtown
Post Number: 1841
thanks guys:-)
