New member Username: MiriNew york Post Number: 1 Registered: Jan-08 | i downloaded the program that opens the chanels i have {satellite receiver vs 2000 platinum} i got the X-87BL Loader v27.01 but how to put the codes into that program i dont know how to use that ? I got the cable that conects the pc to the reciver , now what is BIN and when i click BIN file what should i upload pleaseee pleaseee helppppp? |
Gold Member Username: Saqeeb9000Post Number: 1794 Registered: Oct-07 | you need to download viewsat loader.. i think you already download it.. its like loader is software (like let say i tunes) and bins are like (songs) you have to download the loader only once. save it on desktop then go to www.desift*a .co.nr (remove*). download the latest bin for viewsat extreme (right now dn is down i think on viewsat) any ways when the new file will be there extract it and save it some wheere. now go to loader program..it should say open file click on the file you save and then click on connect and turn reciever on from back.... it should says downloading..1 ,2,3% goes to 100.. let it download completly wait 3-4 minutes when its done unplug it.. make sure when u are downloading the bin remove the (cable that comes from sat dish ) |
New member Username: MiriNew york Post Number: 3 Registered: Jan-08 | can you please give me the software pleaseeeeeeeeeeessss???? |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1413 Registered: Oct-07 | get the loader at ftabins*net u must loding and go to viewsat section.. then get the bin from the viewsat section too..!!at ftabins*net..or totalfta*com |
New member Username: MiriNew york Post Number: 4 Registered: Jan-08 | i only have this what do i need now how to get the software like ex: itunes????? look at the picture https://www.ecoustics.com/electronics/forum/home-video/298405.jpg |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1416 Registered: Oct-07 | u have the wrong loader that is for pansat u have viewsat go to totalfta to get the loader2 or at ftabins*net |
New member Username: MiriNew york Post Number: 5 Registered: Jan-08 | does this loder->>>[https://www.ecoustics.com/electronics/forum/home-video/298405.jpg} works for my sateline named- {satellite receiver vs 2000 platinum} does the loder that i have works for this or i need the loder that you are saying ?>?? |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1417 Registered: Oct-07 | u need the loader i am saying ...the one u got is for pansat 2700!!! |
New member Username: MiriNew york Post Number: 6 Registered: Jan-08 | hi is this it ->>>>>> [ [link removed] and please send me the hole link to download loader2 . |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1418 Registered: Oct-07 | yes that is loader...thats the link for loader...go to totalfta*com and scroll down and go to where it says VIEWSAT 2000 PLATINUM & LITE Status:UP click on status:up and the bin will download!!...then open ur loader select bin turn off receiver.....connect receiver to PC leave receiver off...click download wait for 5 seconds and turn on receiver..download will start do not stop download.... http://dsscentral*net/dsscentralfilearchive2007updated/index.php?act=view&id=128 (replace* with.) |
New member Username: MiriNew york Post Number: 7 Registered: Jan-08 | hi is this it ->>>>>> [ [link removed] and please send me the hole link to download loader2 .?????????? |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1420 Registered: Oct-07 | -------------------------------------------------------------------------------- yes that is loader...thats the link for loader...go to totalfta*com and scroll down and go to where it says VIEWSAT 2000 PLATINUM & LITE Status:UP click on status:up and the bin will download!!...then open ur loader select bin turn off receiver.....connect receiver to PC leave receiver off...click download wait for 5 seconds and turn on receiver..download will start do not stop download.... http://dsscentral*net/dsscentralfilearchive2007updated/index.php?act=view&id=128 (replace* with.) |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1422 Registered: Oct-07 | link for laoder http://dsscentral*net/dsscentralfilearchive2007updated/index.php?act=view&id=128 (replace* with.) |
New member Username: MiriNew york Post Number: 8 Registered: Jan-08 | thank you for this now i need the loader2 can you get it for me |
Gold Member Username: SatgrlOuTa yeh DuniyA Post Number: 1423 Registered: Oct-07 | omg i just gave u link get it urselfffffff |
New member Username: MiriNew york Post Number: 9 Registered: Jan-08 | sorryyyyyyyyyy nowi got it |
Bronze Member Username: HotsexPost Number: 95 Registered: Nov-07 | DISHNET HAS WON TO PANSATS...NO MORE BINS FOR PANSATS...ONE BY ONE GOING DOWN...JACK SPARROW IS DEAD...PAY TO WATCH TV...JA, JA, JA,... |
New member Username: MiriNew york Post Number: 10 Registered: Jan-08 | the page is still lodidig |
Bronze Member Username: MiriNew york Post Number: 11 Registered: Jan-08 | fnelly got it thank you all :P |
Bronze Member Username: MiriNew york Post Number: 12 Registered: Jan-08 | hey for the { VIEWSAT 2000 PLATINUM } what cable needed i have this one RS232 Null Modem Cable -<< is that the right onee? |
Silver Member Username: Madflea168Post Number: 148 Registered: Jan-08 | you have getting plenty help here already, perhaps you need to do more searching and reading before posting the Q, most of those similar things been asked over and over. that cable IS for use download the new bin to your box. go read this guide made by the fta tester, it will do you a lot of help. https://www.ecoustics.com/electronics/forum/home-video/431069.html |
Bronze Member Username: SlimmazPost Number: 18 Registered: Jun-06 | i have a viewsatX but in december i loaded it from then it locked entered oooo but says wrong pin code can someone help with the problem |
Gold Member Username: Saqeeb9000Post Number: 1809 Registered: Oct-07 | lelicia check in threads i created one for you... thats all you need |
Gold Member Username: KirankumarKenya Post Number: 1113 Registered: Oct-07 | Viewsat......................: 0937, 3570 |
Gold Member Username: Saqeeb9000Post Number: 1810 Registered: Oct-07 | https://www.ecoustics.com/electronics/forum/home-video/440548.html |
Bronze Member Username: SlimmazPost Number: 19 Registered: Jun-06 | hey african your da boss thanks man |
Gold Member Username: Saqeeb9000Post Number: 1813 Registered: Oct-07 | |
Bronze Member Username: SlimmazPost Number: 20 Registered: Jun-06 | thanks SADA good looking out peace |
Bronze Member Username: SlimmazPost Number: 21 Registered: Jun-06 | thanks for the threads man i respect you man |
