Hooking up sub to amp...
Username: Ck32
Indiana
Post Number: 17
I have a 4ohm DVC subwoofer and a 2 channel amplifier. I am wondering what would be the best and most efficient way to hook them up.
The Specs for the amp.
2 CHANNEL [2 OHM] 150W x 2
2 CHANNEL [4 OHM] 100W x 2
1 CHANNEL MONO [4 OHM] 300W x 1
The sub is 600w max, 300w RMS and is 4ohm DVC
Thanks for your help.
Username: Van_man
Boston South, MA
Post Number: 3285
hook up each coil to each channel.
Not the best amp for that sub. You should have an amp that does 300 at 2 ohms.
