96 Jetta stereo dead after entering code...HELP!
Username: Ctbrking
I recently purchased a 96 Jetta, there were some dash lights inop so replaced a fuse that I had found blown, when I put the new one in the stereo went into "safe". My wife took it to the dealer to get the code, they tried to enter it and now the stereo is completely dead, not even flashing safe... I tried to pull it out to see if something is disconnected but cannot figure out how to get it out.
Username: Soccergk
Montclair, Nj United States
Post Number: 26
best bet is to take the whole console out to get the radio out if you do not have the keys
Username: Van_man
Boston South, MA
Post Number: 3294
take it back to the dealer and make them fix it. If you just bought it from them it should be under warranty.
