Best Box for Newbies
Username: Jwl1
Post Number: 87
I've heard opinions on what the best box to buy is, what the best box is. Now, I'd like to hear opinons in regard to which is the best box for a newbie to buy and manage who knows absolutely nothing about this hobby in any shape or form.
I started wondering this when a friend said they wanted to buy a box that was easier to update. However, being that the process is basically the same with all boxes, I didn't see how that would benefit him. But, I guess then the issue would be (user friendly) menu, set up and all that other stuff, which would be easier for the newbie to manage.
So, let's hear it...what do you think?
I hit a problem while trying to post this. Therefore, I don't know if it posted. So, if it posted twice, I apologize.
Username: The_coders
Post Number: 182
Username: Madflea168
Post Number: 132
if you look for a box with hardly down, it will be nfusion, members here claimed it takes a little skills to get it started, then it will be all right,
if you look for a box with first bin to come out, it will be hard to decide.
if you want easy use and popular box, you can go with c00lsat, viewsat or pansat.
Username: Jwl1
Post Number: 90
Thanks Mad Flea. I was going to recommend a viewsat for the person, although, I myself, have a Pansat.
Username: 360guy
Ottawa, Ont Canada
Post Number: 21
Hey Coders, if a newbie saw a box like that he may end up playing for the other team.
Username: Scabz
Knoxville, Tn Us
Post Number: 347
Man that is one nasty pic. If I were a noobie I would go for the nfusion, viewsat ultra or the sonic view sv4000.
