I'm new in the FTA and I want to know what is the best receiver to buy for my chalet. I dont want to pay 400$ but I want somethings easy to flash. I already have a pansat 2700A but i cant flash it anymore (I dont know why) Please help me!
get viewsat ultra, easiest to set up and you dant have to disconnect system and brring to computer too upgrade software, Just use flashdrive with the usb port. viewsat and pansat come out with the files before anyone else does, most of the time.. Or a pansat 3500, but you cant upgrade thru usb, if you have a real pansat 2700 and not a clone it can come back to life..try fta4dummies
Good thx! And by the way can someone help me with my pansat 2700A I try to put the new bins in it but my progress bar stay a 0%. I try with my laptop first with a USB to Rs232 converter but no result and no I want to try on my OLD OLD OLD computer the only one in my house who have a Serial DB9 output do I need some driver or somethings like that to transfer my bin or only plug n transfer?
I have just bought pvr7000 and I kind of like it. it works great and DVr option is superb. only cost me 250+100 for HDD. but simple receiver would be any viewsat. they have good file support and easy to program. I still have the fortec and changed to pansat. and still working great.. yeah you will not find them any more..
Newbie here, great forum. I have a dumb question about nfusion: if it's connected to internet and updates automatically, wouldn't others be able to trace where/who you are by looking at your IP address?
