Silver Member Username: Stateprop486PA Post Number: 105 Registered: Jan-08 | are line drivers used to increase pre-out volts on a headunit? lol i dunno thats why im asking. http://cgi.ebay.com/NEW-Phoenix-Gold-LINE-DRIVER-2-In-2-Out-2CH-Line-TLD22_W0QQi temZ120213795198QQihZ002QQcategoryZ14931QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: Van_manBoston South, MA Post Number: 3284 Registered: Mar-06 | yes |
Silver Member Username: Stateprop486PA Post Number: 106 Registered: Jan-08 | http://cgi.ebay.com/Pac-Turbo-1-Turbo1-Pre-Amp-Line-Driver-Signal-Amplifier_W0QQ itemZ190192413755QQihZ009QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ? |
Gold Member Username: Van_manBoston South, MA Post Number: 3286 Registered: Mar-06 | same thing, just an off brand. |
Silver Member Username: Stateprop486PA Post Number: 107 Registered: Jan-08 | so i just bought a 7" indash panasonic indash it only has 2volts pre-out could i use one of these to increase it to like 5 volts without damaging anything? |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17370 Registered: Oct-05 | if you must use a line driver, look at the memphis one. i really like that one. its very simple and works great. but before you go out and do that, first see how it sounds. you never know man. you might like it. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17371 Registered: Oct-05 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4349 |
Gold Member Username: Denali_on_22sThe kids like my rhyme... Post Number: 3740 Registered: Feb-06 | i wouldn't worry about it man, youll be fine with 2v... line drivers provide shitty signals a lot of the time |
Silver Member Username: Stateprop486PA Post Number: 108 Registered: Jan-08 | haha yea thanks chad i saw the memphis one on Ebay, but these do really work though? the line drivers? o yeah i get it on Tuesday i cant wait. lol |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17373 Registered: Oct-05 | well i've seen the memphis one in action and it does work well. |
Silver Member Username: Stateprop486PA Post Number: 109 Registered: Jan-08 | lol im just afraid the i wont be use to the sound because the premier HU i have now is 5v pre-out. so i dunno lol...o well if i dnt like it ill just sell it on ebay. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17374 Registered: Oct-05 | after you get the indash and you don't like the sound, get yourself a audiocontrol eq. audiocontrol ups the voltage too. it has a built in line driver. |
Silver Member Username: Stateprop486PA Post Number: 110 Registered: Jan-08 | o really, which one would u suggest chad? thanks for your input guys, i really appreciate it. o yea reece any luck on findin indash monitors compatible with the pioneer dvd playeR? |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17375 Registered: Oct-05 | don't know. there are many to choose from. you gotta check to see which would be most suitable for you. anyways don't concern yourself about that right. first install the indash. you might like it. lol. |
Silver Member Username: Stateprop486PA Post Number: 111 Registered: Jan-08 | haha okay bro. thanks again. |
Silver Member Username: MmaudioconceptsPost Number: 369 Registered: Jan-07 | the JL audio line driver is great as well... |
