Locals?
Username: Achilles
Post Number: 43
Do local channels work? I have a SonicView SV1000 with 2.90 bin and autoroll and auto tp update on. (should I have any off?) And well, looks like ABCFM is the only channel working. Is it just me? How can I fix it to get my locals back?
Username: Achilles
Post Number: 44
Bump.....
Username: Kirankumar
Kenya
Post Number: 1063
try re scanning
Username: Lol
Post Number: 271
map your locals
Username: Achilles
Post Number: 45
What do you mean by that? How do I map my locals?
Username: Thehutch
Post Number: 8
Do a blind scan of both satellites, select position "vertical" and scan "all".
Username: Achilles
Post Number: 46
Still not working.... Are the local channels even working for anyone else?
Username: Tigger_woods
2008 RESOLUTION, I WILL BE NI...
Post Number: 395
Go to channel 9125 and you will find over 100 local channels. 19031 will give you Clinton News Network, better known as CNN.
Looks like I am going to miss the Republican debate on PMSNBC, unless bin comes out before 9 pm.
Might have to watch American Idle, I am rooting for this cool singer named, Taylor Hicks. If you have not seen or heard him yet, the guy does Joe Cocker and Otis Redding stuff. Awesome singer.
Username: Achilles
Post Number: 48
So just enter 9125 and I will find over 100 local channels? How? Everything to me is "Please wait for update"
Username: Achilles
Post Number: 49
Bump
Post Number: 402
I have a pansat,vs plat and lite and a cw 600 premium. They all work on 9125 and up/down from there, aprox 100+ stations all abc,nbc,cbs,fox,pbs from all over and cnn at 19031.
If you have one of the units I mentioned on latest bin you should get all those.
Post Number: 403
I assume sonic view is same, see how high you can go, find ch 100 and go down till you get in the 4 digit numbers??
