Silver Member Username: Fortec16
Post Number: 176 Registered: May-06
Posted on 118 Universal LNB is not showing the signal for yellow card rom102 receiver. Should I change standerd LNB? Which LNBworks for both? Gus |
Gold Member Username: Nydas
Post Number: 7582 Registered: Jun-06
Posted on Don't do anything till you have read 2-3 forums about your set up. |
Post Number: 177 Registered: May-06
Posted on Hi Nalin, What do u mean by 2-3 forums about your setup???? I set it for 118 and tranport 01 Checked the switch after 0-38 done. Now no signal only scaning default??? Help??? |
Post Number: 180 Registered: May-06
Posted on Nalin, answer please |
