Silver Member Username: Noob101Taylorsville, Utah USA Post Number: 134 Registered: Jul-07 | My speakers have been turning off since i installed them they work fine on lower levels but if i turn it up at about half-way they'll work for about 3-10 min. and then they'll turn off until i turn it back down towards the lowest volume levels there running off of my stock head-unit. At first i thought it was a charging problem but when they last turned off i looked back at my amp to see if the green power light was on and it was still on. Thanks for any help. |
Bronze Member Username: Stateprop486PA Post Number: 93 Registered: Jan-08 | ur amp settings may be too high. |
Silver Member Username: Kpa2727Post Number: 859 Registered: May-07 | yea ur clipping them back the amps gains down. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5752 Registered: Jul-06 | Did you set the gain right. Sounds like the gain is too high or the amp is going into thermal protection. |
Silver Member Username: Noob101Taylorsville, Utah USA Post Number: 135 Registered: Jul-07 | How do i know if the amp gain is right? the gain is very low and bass boost is off should i turn the gain all the way down as well then? and see if that fixes it? |
Silver Member Username: Surferdude9371Admiting your an a$$ho... Post Number: 516 Registered: Mar-07 | http://www.subwoofertools.com/forum/setgain.asp this should help ya |
