Username: Hockeys_back Post Number: 60 Registered: Oct-05
Saturday, January 26, 2008 - 02:08 GMT does anyone know if an old bin is working for the ariza under bev??
Username: Way2smart DESIFTA .co.nr
Post Number: 699 Registered: Oct-06
Saturday, January 26, 2008 - 02:10 GMT hockeys dude i dont think no 1 has ariza here might wanna check ftabins.net !!Good Luck also viewsat is up on bev
Username: Lookekhoshshans_1356 Tehran,
Tehran
Iran
Post Number: 16 Registered: Apr-07
Sunday, January 27, 2008 - 01:18 GMT There is no new Ariza file out for DN There is no new Ariza file out for BEV some older files may be working for BEV. There are no bins out for Ariza 700/750/800S yet as of 1120 PST sure, once new bins are out ,they will be posted on [link removed] you have to with
Username: Tehrani Iran,
Tehran
Iran
Post Number: 104 Registered: Oct-07
Sunday, January 27, 2008 - 01:24 GMT yes you are right . If new bin fix out , it will come first [link removed] mingi fix for all kind Ariza thank mingo
Username: Alime_123 Afgh,
Ghazni
Afgh
Post Number: 69 Registered: Oct-07
Sunday, January 27, 2008 - 01:34 GMT hi when i set up my Ariza T_5 and 110 ech CHANNEL are (OVERPLUS)or BIGEMINAL set up when I set up every thing is ok but it ech CHANNEL are (OVERPLUS)or BIGEMINAL it take my time to delet thank you so much
Ghazni
Afgh
Post Number: 71 Registered: Oct-07
Sunday, January 27, 2008 - 16:35 GMT Hi all Is Hotbird Satellite On Ariza 700? how can i get Hotbird Satellite with Ariza700? can some one help plaese? thanks alot
Username: Burnabyh Toronto,
On
Post Number: 32 Registered: Aug-07
Sunday, January 27, 2008 - 23:04 GMT 306 is working for B3V
Tehran
Iran
Post Number: 18 Registered: Apr-07
Monday, January 28, 2008 - 00:32 GMT 306 isnot working for B3V but it can get some chanell it can not get PPV and alots of chanell. it is too old
Tehran
Iran
Post Number: 23 Registered: Apr-07
Monday, January 28, 2008 - 13:45 GMT hi all good morning new fix came out this morning MINGO ARIZA fix for ARIZA 700 700s 750 & 800 V2 Jan 28 2008 I would like to thank everyone who was understanding and waited. Everyone was in the same boat. Hope it lasts. The ball is back on our side of the field. Take care and enjoy. Posted here at [link removed] First. but i didnot test it Thank you MINGO><OGNIM Attached Files
Tehran
Iran
Post Number: 108 Registered: Oct-07
Monday, January 28, 2008 - 14:33 GMT It tested it is work fine for bev
Ghazni
Afgh
Post Number: 74 Registered: Oct-07
Tuesday, January 29, 2008 - 00:09 GMT hi all Thank you so much lookekhoshshans It works fine
