Vs 2000 ultra
Username: Soprano
had a power outage while down loading a bin during donot power off stage can not get anything at all is there anything i can do
Username: Nydas
Post Number: 7477
You can try a serial load of the factory BIN - I think it is 131 for version 2. Check it out at
[link removed] or
[link removed]
Username: Soprano
re vs ultra
i looked up the files you suggested but i can't seem to get power to the reciever am still looking for any solutions
Username: Bbplayer
Post Number: 15
do you have any lights on. or - - - - - -
in front ?
Username: Ontarian
yea i got the same problem.. BB player im just getting the ----- in front of the receiver any ideas how i can get power to it??
Username: Feroz
New york, New york U s a
Post Number: 25
i had d same problem and u cant use usb to load new bin u will have to use cable that came w the box
Username: Ontarian
Edgar can you tell me what program i use to load the bin file on to the box using the computer??
Username: Feroz
Post Number: 26
........b let me check d vs ultra ill b back
Username: Feroz
Post Number: 27
b loader2 itcan b found in dvs file out dsscommunity//.com or i can email it
Username: Ontarian
sure Edgar if u can send it to me at my email adress
bryan_s2000@hotmail.com
Username: Feroz
Post Number: 28
..bryan did u received it !!!!!im had problems w/ hotmail ind past so let me know
Username: Ontarian
thanks Edgar for your help
Username: Bbplayer
Post Number: 17
you may have to load vs ultra fail fix.you can get it from newb`s.you can get vs loader v11
their to.after loading do a factory reset and load vs ultra 131 and new files good luck
Username: Feroz
Post Number: 30
welcome b did it work ok?
Username: Soprano
frank ciciarelli
no i have lights or power to the unit that i can see
Username: Soprano
frank ciciarelli
no i have lights or power to the unit that i can see, i have a call into veiwsat but the tech wanted me to remove the cover to see if was the real deal but he has not got back to me yet
Username: Soprano
i have the factory bin and mainpage and sat info ,i made a copy when i first bought the unit in case of problems you would think there would be a reset button or something like for cases like this
