TSN is screwed up?
Username: Brucelee
Beverly Hills, California United States
Post Number: 128
What the hell is wrong with TSN? Every now and then the signal disappears and it says "searching signal"? When other channels on BEV are showing 100%? I tried rescanning for that channel only and it's having difficulty searching that channel, frequency is 12574.
Username: The_coders
Post Number: 167
tsn is fine , something wrong on your end - alignment ? switch ??
Username: Saqeeb9000
Post Number: 1728
hi pete if there is only problem with one channel and ur other channels are working fine.. try to delete all channels and scan them again. ... this should work... if not try a factory reset, new bin and scan channels again..
Username: Brucelee
Post Number: 129
I'll try again, it was back just now for like 15 minutes and is gone again?
Darn!
