Username: Diehlerman Post Number: 2 Registered: Jan-08
Wednesday, January 23, 2008 - 06:30 GMT ok, since my thought on the kenwood amp was shot down. i did a little more looking and found a couple more that caught my eye. anybody know anything about MA audio or DB drive? if its any help i have two 10" alpine type-r's 4 ohm DVC. so im needing 1000wrms, and i was planning on wiring for a 1 ohm load.
Username: Drant19 DUB-C,
TX
Post Number: 259 Registered: Aug-07
Wednesday, January 23, 2008 - 06:37 GMT whats your budget for the amp? i would steer clear of the MA audio amp. i dont know the DB drive so i have no input on that. but post a budget and we can go from there
Username: Diehlerman Post Number: 3 Registered: Jan-08
Wednesday, January 23, 2008 - 06:38 GMT no more that about 500
TX
Post Number: 260 Registered: Aug-07
Wednesday, January 23, 2008 - 06:45 GMT oh wow...a Rockford Fosgate T10001BD would suit those perfectly. underrated amp that puts out close to 1400rms. also a kicker kx1000.1 would be good. also underrated and is close to 1500rms. the type-r's like some power so 600-800rms each would be IDEAL.
TX
Post Number: 261 Registered: Aug-07
Wednesday, January 23, 2008 - 06:45 GMT oh wow...a Rockford Fosgate T10001BD would suit those perfectly. underrated amp that puts out close to 1400rms. also a kicker kx1200.1 would be good. also underrated and is close to 1500rms. the type-r's like some power so 600-800rms each would be IDEAL.
TX
Post Number: 262 Registered: Aug-07
Wednesday, January 23, 2008 - 06:46 GMT sorry for the double post. but i meant the KX1200.1. like i said in the 2nd post. also an kicker SX1250.1 would be nice...all these amps are underrated
Username: Diehlerman Post Number: 4 Registered: Jan-08
Wednesday, January 23, 2008 - 06:57 GMT alright...ill definately go give those a look. thanks.
TX
Post Number: 263 Registered: Aug-07
Wednesday, January 23, 2008 - 07:01 GMT no prob. all are quality amps
Username: Nd4spd18 Northwest PA
Post Number: 5695 Registered: Jul-06
Wednesday, January 23, 2008 - 17:42 GMT in addition the all the amp abarca listed: Sundown SAE-1000d Audioque 1200d $279 probably the best value for a good amp
Username: Pbplayer05 Carroll,
Iowa
Post Number: 257 Registered: May-07
Wednesday, January 23, 2008 - 21:31 GMT well u could get a usamps md2d or even and md3d they would both work well i just got my md2d for 319 nad it does 1500+
Username: Ctmike Ct.
Post Number: 5750 Registered: Feb-06
Wednesday, January 23, 2008 - 22:03 GMT i'd take a sundown saz1500. can be bought bnib for under $500 and would work perfectly.
TX
Post Number: 270 Registered: Aug-07
Wednesday, January 23, 2008 - 23:53 GMT the sundown amps would be easier on your electrical and wouldnt require a HO alt.
Iowa
Post Number: 258 Registered: May-07
Wednesday, January 23, 2008 - 23:56 GMT well the usamps are very efficient
TX
Post Number: 272 Registered: Aug-07
Thursday, January 24, 2008 - 00:01 GMT true^^^ either or...allthe amps mentioned are great but the USamps and Sundowns are most efficient
