Is anyone having an issue with this receiver. I am using it on a moving a dish and I have the channels freezing is this because of a new ECM in the mix or do I have another issue with my system?
yeah it will stay on the satellite for about 15 minutes then it starts drifting off is this common can this be stop or should I use my other receiver to control the dish.
1- load factory bin 2- load current bin(available at www.crazyftadotcom) 3- check your settings 4- scan your birds. 5- turn off rear switch for 2 to 4 minutes then turn switch on good luck
