Where can i buy Genuine aero ports???
Username: Mendonmafia
Post Number: 843
lookin to get 2 6" ones. i cant find them any where, where is the cheapest price i can get these from.
also when using winISD to calculate box tuning they have a feature that allows you to choose from one flared end or 2 flared ends. should i use this feature to determine my tuning or is it bogus? it ends up reducing the total length of the port by a considerable amount.
last question. how do you account for the volume displaced but the port? do you account for the flared part? if so what is the volume of that?
RD 1000.1D with SI MAG...
Post Number: 17199
www.partsexpress.com
when i tune aeroports, i usually add an inch to the the length.
Post Number: 17200
scroll to the bottom of the page. damn they even have 6 inch aeroports now. i need to pick one up.
http://www.partsexpress.com/webpage.cfm?&WebPage_ID=3&Start=2&CAT_ID=48&ObjectGr oup_ID=143&sm=1&so=2&desc=ASC
Post Number: 845
wow thats the exact opposite of what winISD does. winISD makes the length shorter.
Username: Bjfish11
Garden Plain, KS USA
Post Number: 359
Here is where I get them most of the time...
http://www.thrilleraudio.com/searchresult.aspx?CategoryID=12
Post Number: 17201
well i got my calculation from this site. if you notice it adds an inch to the length if its an aeroport.
http://psp-inc.com/psp-inc.com/public_html/..%5Ccgi-bin%5Cport_length_calculator .cgi
Post Number: 17202
also i don't see how a port gets shorter if you flare out the the ends of the port. doesn't make sense to me. bigger the port area means longer the length to achieve the same tuning.
nice site fisher.
Post Number: 846
hmmmmm.......
Post Number: 847
good point chad. well i dont need that much area any ways so i think im just going to go with my origional 4x13 inch square port.
Username: Bjfish11
Post Number: 360
The best thing about that site.... is if you have left over tubes, you can buy just the flares and connector rings, and dont have to buy a whole new set. Saves 3-4 bucks at a time. If you order enough to complete 15 sets, your looking good ;)
