Need help B&W 602's anything else that compares to price and value?
Username: Salt232
Orem , Ut Usa
I am revamping my home theater and need a bookshelf for my fronts. I have auditioned the 602's but I have heard wonderful things about other speakers I really want to make the right choice I am up for suggestions, please advise.
The speakers will be powered by a Marantz 4001
Username: Gmach1
Calgary, AB Canada
Post Number: 7
I think you should listen to Monitor Audio as well. I believe the Silver series is in the Same price range as the B&W 6 series.
Username: Salt232
Orem , Ut Usa
Thanks for the information, is ascend acoustics something that could be comparable?
Username: Frank_abela
Berkshire UK
Post Number: 2654
Please note that the B&W 600 series has been discontinued and replaced with the 68x series. The cheapest in the new series is now the 686 which is similarly priced to the 602, but in terms of size the next model up, the 685, is closer to the 602.
Other speakers you may wish to consider would be Totem Dreamcatchers AND Focal'S 705V or 706V. All have appropriate centre speakers to match.
Username: Salt232
Orem , Ut Usa
Thanks for the insight on the B&W's. Will a Monitor Audio rS2 Hold it's own with a 602 ? I checked out totems website will look to audition them where I can as well.
Berkshire UK
Post Number: 2668
I haven't that much experience with the MA speakers I'm afraid.
Username: Salt232
Orem , Ut Usa
Is aperion a speaker cmpany worth checking into?
