1 Question about box design
Username: Ducka
Shelby Township, MI United States
Post Number: 24
I am planning on building a box for 4 subwoofers. Would it sound alright if 2 of the subs were facing forward toward the inside of the car and the other 2 were on the opposite side of the box facing out the trunk?
Username: Deadrabit
Post Number: 131
is it ported? will u have two ports facing the front and two facing the back? or is it sealed?
Username: Ducka
Post Number: 25
I was either going to have it sealed or have to 6 inch ports on top of it. Depending on how big I want the box.
Username: Nd4spd18
Northwest PA
Post Number: 5721
All subs should be on the same side of the box if it's common chamber. At least thats what I hear from most box builders.......
