CS_241_Lightning and jvvh_241
Username: Nydas
Post Number: 7422
These files for BEV fix are available at:
[link removed]
http://public.box.net/2500_full_kit
Use only on 2500/FLU to 2700 conversions.
Username: Leafs
Post Number: 381
file posted at www.ftasolutions.blogspot. com
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 238
thanks Nalin, but whats the difference between this 2 and the 239 files...
Username: Nydas
Post Number: 7437
241 is a BEV fix for BEV ECM of 19th January.
DN works fine on 240
Username: Shadow45
Post Number: 241
Thanks for the info dude, btw could you help me with this issue please?...
https://www.ecoustics.com/electronics/forum/home-video/437260.html
Username: El_che
Post Number: 15
which bin is better for my pansat 2500 clone converted to 2700. i'm always having this kind of question when a new bin come out, never know which to choose, jvvh version or lightning. thanks
Username: Dishlover
Toronto, Ontario Canad
Post Number: 99
Aby use CS_241 or JVVH241 available at
www.dssworld.co*.nr/
remove *
Username: El_che
Post Number: 16
ok thanks,
Username: Viruscauser
Leesburg, Georgia
Post Number: 751
If you only watch DN and nothing else, stick to the jvvh_239 bin. It's a much more stable bin and you can safely leave the autorolls ON.
Just my $0.02.
Username: El_che
Post Number: 17
since i out this new bin, my signal level decreased to 34%. i checked my cables and everything is ok. any idea
Username: Dishlover
Post Number: 100
Suddenly my receiver showing No Sgnal. Any idea why? It was running perfect with JVVH 239 until late afternoon. Please help.
Username: Destine0429
Quebec Canada
Post Number: 410
Can someone plz confirm if this new bin takes away the signal plz.
Username: Nydas
Post Number: 7440
Julie: Use jvvh_240 or 241 for DN. use jvvh_241 if you are scanning BEV
Quebec Canada
Post Number: 411
Thanks. SO the signal doesn't go to 0?
Username: Nydas
Post Number: 7442
Right now I have tested jvvh_240 for over 24 hours - absolutely first class.
Quebec Canada
Post Number: 412
And that works for Bev?
Username: Nydas
Post Number: 7445
jvvh_241 for BEV
Username: Palau
Hercules, Coahuila Mexico
Post Number: 7
Hi I got a Lava 3200 converted and I am trying to use jvvh_fortecRemote_240, with loader 1.4.0 but after the burning loader says write failed. I am using port com 3. Please help!
Username: Nydas
Post Number: 7447
You should look at the variables such as connection, type of cable, timing - start as soon as "b" shows in the receiver.
If everything else fails, you could download the full_kit, read the instructions and consider revert to 2500 and restart. It is pretty easy.
Username: Palau
Post Number: 9
Thanks Nalin. I already tried everything and it starts downloading and it gets to 100% and then it starts burning (at this time the reciever goes to ON)but after a while, actually long while, it says write failed.
I will try the other option you gave me.
Username: Nydas
Post Number: 7451
"gets to 100% and then it starts burning (at this time the reciever goes to ON)"
Sounds like you do not have boot B75 in or a bad boot B75.
After BURN, it should reset and do a b-7-5 horizontal dance, pause at "5" and then turn to ON.
Username: Palau
Post Number: 10
Nalin I went into Public.Box.net, and I registered but it gave me no 2500 full kit. Where can I get it?
Username: Palau
Post Number: 11
Nalin, what should I do then...if I have a bad B75
Quebec Canada
Post Number: 413
What's the difference between the CS_241_lighting and the jvvh_Pansatremote_241?
Username: Nydas
Post Number: 7454
Alfredo Santos Gonzalez : All you have to do click on the URL and download a file. There are four files. One of them is called full_kit11a.zip.
After downloading you unzip and read teh instructions and follow them. There are instructions for reloading B75.
Username: Nydas
Post Number: 7455
Since the 239 fiasco of CS_files, I have preferred the jvvh_ files made by fwank7.
Username: Dishlover
Post Number: 106
JVVH 242 is at DSS world.
Username: Nydas
Post Number: 7489
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_242T_lightning and jvvh_242 files for Pansat or Fortec remote '" for DN and BEV fix
The latest CS_BevT_lightning file and the old jvvh_209 and jvvh_213 are also working well with BEV and are included in a separate directory and in separate files.
The 240, 241 and 242 version conversion files are available separately as well
Some of the older versions and jtag files are also included.
The full kit is in full_kit11C.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file.
Username: Khova
Post Number: 19
JVVH 242 possibly a stupid question but does it work on a fortec clone converted to a 2700
Username: Nydas
Post Number: 7495
Yes
Username: Asharfi
Post Number: 1729
Yes, friends! Bin 242 has been released by FWANK7 under JVVH's name. I don't know if Chancysand Bin is out or not, but you can watch TV with this new JVVH bin 242. Enjoy ... files are available at dssworld and crazyfta
Username: Nydas
Post Number: 7499
AV: "I don't know if Chancysand Bin "
Both the jvvh and Chancy 242 Bins have been out for 6-8 hours.
Username: Shadow45
Post Number: 244
Just a dumb question , but why are they releasing the 242 files if the 239 is still up and running?...is there any difference , do they come with Close caption again?
Username: Popol_vuh
Alfredo Santos Gonzalez, if you have trouble accessing the Box site turn javascript on. I had the same issue today, it appears Box must have done some changes to how it works.
Username: Locnoir
Post Number: 57
Shadow45, Close Caption works on 241 file. I have not tried the 242 yet.
Username: Nydas
Post Number: 7506
For DN: The jvvh_240 is definite improvement over jvvh_239. 241 was short lived - it was released as a BEV fix and BEV put a new ECM The jvvh_242 and CS-242 are the latest complete solution for DN and BEV.
SHADOW45 : If you had both DN and BEV on your box, you can only use the 242 BIN.
