Good sub combo to match this amp
Username: Whoaitstony
just wondering if anyone has used this amp and what good subs should i be looking for to match with this amp. http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=7 &family_id=22&item_id=95251&locale=en_US&p_status=
my budget on the subs will probably be around 400-500 dollars and will probably want 1 or 2 12"s or 1 or 2 10"s
Username: Ska
Post Number: 170
you can get a better amp for ALOT cheaper, what is your whole system budget?
Username: Stateprop486
PA
Post Number: 36
def can do better bro. wat do you want out or ur system? sq? spl? etc..tell us, where help
well the thing is i already have the amp i got it as a present for christmas, i was just lookin for wut subs would work for this amp that would have good sq and spl
Username: Ska
Post Number: 171
a 13w7 lol
what are the price ranges on the 13w7?
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1616
What car is it going in???
03 accord coupe
Username: Nickyp0219
Post Number: 385
thats a damn nice xmas present lol
Username: Skibum12189
Cleveland
Post Number: 2495
2 12" RE Se's
http://cgi.ebay.com/2-RE-AUDIO-SE12-12-SE-SUBS-RESONANT-ENGINEERING-pair_W0QQite mZ180209606729QQihZ008QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
did you used a sealed or ported box for those RE 12"s?
Post Number: 7
and also my friend told me i cant run 2 12"s on dual 4 ohms and i need dual 2 ohms if i want to run 2 12"s. is that true?
Username: Mj23dynasty
They Love 2 Hate Me, Most Hated a... USA
Post Number: 1143
You can run dual 4 ohms if ur amp is 1 ohm capable.
It had nothing to do with the size of the sub
Username: Denali_on_22s
Post Number: 3665
that fosgate amp is a VERY nice amp. saying you can better a better 1000 watt amp for the price is questionable. that amp will probably put out 1200-1500 watts. i would go with a couple of audioque SD2.5s. they will have pretty good SQ and get real loud.
Post Number: 3667
also your friend is an idiot. you need two dual 4 ohm subwoofers so you can wire your amp to one ohm.
PA
Post Number: 40
www.audioque.com
Post Number: 8
so ur saying im able to run 2 4 ohm 12"s with the amp i have? also what kind of setup for those subs are you running in your car? thanks
Username: 420alldaylong
Post Number: 3213
AudioQue HDC3 12"
AudioQue.com
Post Number: 3214
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Post Number: 9
so should i run 2 or 1 of those AudioQue HDC3 12" in my accord?
Post Number: 3215
1 AudioQue HDC3 12" Dual 2ohm
And wire it this way.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Post Number: 11
so do i wire it as the 1 ohm load or the 4 ohm load?
Username: Kyle_lowe
Post Number: 779
1 ohm load
Post Number: 3216
1ohm
Post Number: 13
alright thanks guys for all the quick msg's i'll work on gettin those subs. one last question tho, when i get a box made should i be sealed or ported?
PA
Post Number: 44
def ported for AQ HDC3's!!
Post Number: 3217
Email Audioque and they will answer all your?.
Username: Nd4spd18
Northwest PA
Post Number: 5670
Awesome amp you got there
