Alternator
Username: Waresgaragestereo
Fort Valley, GA United States
Post Number: 70
1990 Cadi DeVille stock all the way. Can anyone tell me how to figure out how many amps the stock alt puts out. I believe its 120 but still i want to know how to find out. I have a volt meter but i didn't know if that would do any good. if not, what do i need?
Username: Nd4spd18
Northwest PA
Post Number: 5780
It is 120 amps. Remember though, idle amperage will be significantly less.
Username: Eldog
Pittsburgh, Pennsylvania
Post Number: 23
My 89 Eldorado also has a 120 amp alternator. Will I have to upgrade to a 200 amp alt or just do the Big 3 and a fresh yellow in the trunk or should I just do the 3 and a fresh yellow ? Running a ZX 1500 and a ZX 650.4.
Username: Nd4spd18
Northwest PA
Post Number: 5790
Yellow tops are not the best for car audio by any means. But you don't even need to worry about the battery, it will do fine.
HO alternator and big 3 will probably be needed.
120 amps is big for a stock alt though, you could try it and see what happens.
Username: Eldog
Post Number: 25
Good look M.S.
Post Number: 75
Whats a big 3? I've haard it refered to many times on the forum and have no idea what it is.
Username: Nd4spd18
Northwest PA
Post Number: 5806
Dude, your name would make me think that you own a shop, but I really hope you don't, knowing this little about car audio.
Big 3:
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
Username: Th3pwn3r
Post Number:...
Post Number: 6663
^I thought the same thing when he first came here but I don't think he owns a shop either haha. The big 3 is just changing out your charging systems wiring to a thicker gauge. Alternator to battery positive, alt case to chassis, battery negative to chassis.
