Help with Fortec Lifetime Ultra
Username: Pgomes
I've tried downloading the new files for the flu (the 240s and 241s), but when I connect it to the cables, the receiver simply displays "On". Nothing ever changes even if i press ok on the remote.
Username: Nydas
Post Number: 7463
Turn off receiver.
Get Straight RS232 cable (NOT a null cable)
Connect the cable.
Stat BL Updater 1.4
Select BIN.
Get ready to Write.
Turn on receiver and when "b" appears on th e receiver, click on write.
WAIT ... WAIT
If will go through 10-100%, then BURN.
Then when th ereceiver says b-7-5 and stays on 5 do NOT switch off.
Only when it comes to ON switch off.
Remember you still have to set up the receiver with the antenna cable and TV.
Username: Pgomes
Actually the problem persists when I connect the receiver to the television and antenna cables. Nothing appears on the tv screen and it only says "On".
Username: Nydas
Post Number: 7464
Do you get b75 scrolling accros when you turn receiver on from off position?
Username: Dure
Mississauga, Ontario Canada
Post Number: 161
Try, Select ur satellite and do a Blind scan for channels.Hope signal quality and strength is there.
Username: Pgomes
I still get the b75 flashing, but when it gets to On it freezes and nothing appears on the screen and nothing occurs when you press ok or any numbers on the remote.
Username: Nydas
Post Number: 7470
Gomes: The only thing I can suggest is to redo the conversion.
You can first revert to 2500 using Chancy's reversion instructions.
All this and the exact instructions are included in the Full_kit11A. You will have to unzip the file in a new directory "jvvh" and then read/print the instructions. The reversion is in the "Revert to 2500" directory.
Username: Jagr1234
Post Number: 166
can you load a channel list while it says on? try that...it may work.
Username: Jagr1234
Post Number: 167
in addition. i had issues with my fortec overwriting 239. had to factory reset then write 240. 239 was horrible on my fortec...fine on my pansat.
Username: Pgomes
K Thanks for all your help folks, I'll try it out in the morning.
