High sensitivity
Username: Trunkslayer
Fl US
Post Number: 32
I was wondering if someone could point me in the direction of a high sensitivity twelve. Power cant be more than 450 rms. Long excursion is preferred but ok if not.
Username: Mendonmafia
Post Number: 825
jbl p1222 97 db sensitivity
Fl US
Post Number: 33
Hey man that sounds good and they are pretty cheap on ebay.
Username: Rovin
4 10 Pioneer...
Post Number: 12861
audiopipe subs have a high sensitivity too ......
Username: Nd4spd18
Northwest PA
Post Number: 5644
I think the old Infinity Prefect 12.1 were pretty efficient
Post Number: 831
the 12.1's were rated for 96 db but that was an im car efficency (not sure which car lol, but thats pretty dirty of them). actual according to winISD is more like 86 db. however they did seem very efficient i put the pair of mine on 1000 watts daily and then switched to my sub channel on my zx700.5 just to test it and they were only a littel less loud. but you will have a hard time finding these anyways
Username: Tejcurrent
Post Number: 1013
check out these graphs for some ideas:
http://bigbassman.realmofexcursion.com/images/graphs/dbwatt-ported.gif
http://bigbassman.realmofexcursion.com/images/graphs/average-ported.gif
You can see the Stereo Integrity BM does well, and it's 500rms so it would be fine on 450.
Also the RE SR series did pretty well with 400rms.
Fl US
Post Number: 34
Well what is probably better, the JBL or one of the subs from this graph.
