Amp settings...need help
Username: Sportquest
Nashville, TN USA
Post Number: 24
hey guys, I'm having some issues with my amp settings, I had the right settings for it, but i played around with it and cant remember what the settings were originally. Any help with the right settings would be appreciated.
The amp is a Alpine MRP-M650.
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=500MRPM650
Here's a link to the settings, click on see more photos and video and a blown up photo of the settings will show.
Username: N2audio
Lawrence, Ks USA
Post Number: 1447
gain depends on your hu - probably between 9:00 and 12:00
bass eq - 0 or very little
lp filter - personal preference, depends somewhat on the rest of the system, but generally 75-100
Username: Oreos
Tallahassee, Florida USA
ok this is how you adjust your gain,first turn gain all the way down, then turn your radio 3/4 of the way up, then slowly turn up your gain till your speakers starts to bottom out, then turn it down just a little and your set
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5132
yes, that helps.
if you have bass boost, don't mess with it and subsonic, depends if you have a ported or sealed box.
