Bronze Member Username: MajkPost Number: 33 Registered: Nov-05 | This is for fortecs and pansats 2500 conversion Bev and DN fworking |
Bronze Member Username: Luv2meetPost Number: 21 Registered: Dec-07 | thx deki ... it works. |
Bronze Member Username: Hamid9272Post Number: 35 Registered: Nov-06 | confirmed.. it works... i just tried... |
Gold Member Username: NydasPost Number: 7418 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest CS_241T_lightning file The latest jvvh_241 files for Pansat or Fortec remote '" for DN fix The newest jvvh_241 files for Anik3 scan '" for DN fix Some of the older versions and jtag files are also included. http://public.box.net/2500_full_kit The full kit is in full_kit11Azip. Unzip into a new jvvh directory. The 240version and 241 version conversion files are available separately as well. |
Bronze Member Username: DishloverToronto, Ontario Canad Post Number: 98 Registered: Jun-06 | All lates files available at Replace * with dot |
