i want to drive 2 12" SX's in about 2-2.5 cubes each and tune it low probably like 32 hz or so and i want to know what port area i should use to get the best results. i would prefer to do the smallest port as possible but i dont want any vent noise and i dont want to lose output.
do 50 square inches of port tune even at 2400 watts at a 32 hz port tune youll be fine ....linear team claims a vent mach of .04 and .16 is considered unacceptable but id stay lower than a .12 vent mach as a limit
from what ive seen on realm of excursion out of the entry level re 12 re series sub I got you bet....im going to run one or two daily I think but im not sure yet....if not ill be using one or two for spl comps
