Bronze Member Username: Jebeni61Post Number: 19 Registered: Jan-08 | Hi guys I have jwh 240 pansat remote inpansat 2500 to 2700 and No signal..i am looking for 110 or 119 any suggestions? had jwh239 before,, signal was ok.. didn`t move my dish or lnb..what would be correct set up.. to get 110 or 119? |
Gold Member Username: NydasPost Number: 7356 Registered: Jun-06 | The full kit is in full_kit10zip. Unzip into a new jvvh directory. Read the Instructions file 119 and 110 are always tricky - a lot depends on the type of Dishs and LNBs. However, mostly people use 119 - port 1 and 110 - port 2 or none. Scan each separately with the other port disconnected in antenna setup. Do you have 22khz swithc? - If so, you will have to set it to on for one of them in antenna setup. Always remember to write down your working settings for use next time |
Bronze Member Username: Jebeni61Post Number: 20 Registered: Jan-08 | thing is I don`t use switch or port at all;( |
Gold Member Username: NydasPost Number: 7420 Registered: Jun-06 | Use 119 - Port 1 Freq 11250 110 - Port 2 Freq 11250 or try (port = none) Scan 119 first with 110 set to none. Then set 119 to none and 110 to port 1 and scan. Then set 119 to port 1 again, but do not scan |
Gold Member Username: NydasPost Number: 7430 Registered: Jun-06 | Dav Patel asked: Posted on Sunday, January 20, 2008 - 12:37 pm: hi Nalin i have 2 converted pansat 2500-2700a and i am using blacklist updater1(1).4 for loading file.lately when i am trying to load file i am having problem to load the file some time it goes up to 100% then it says write fail.some time it goes up to 46% and some times its turn off my computer.nalin can you help me for what's wrong,and i also fried my other receiver for trying to load the file. i can't turn on my receiver.can you help me to turn on my receiver please. |
Gold Member Username: NydasPost Number: 7432 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest CS_241T_lightning file The latest jvvh_241 files for Pansat or Fortec remote '" for DN fix The newest jvvh_241 files for Anik3 scan '" for DN fix Some of the older versions and jtag files are also included. The full kit is in full_kit11Azip. Unzip into a new jvvh directory. The 240version and 241 version conversion files are available separately as well. Read the instructions file and do a revert to 2500 first. Then start all over again adhering rigidly to the instructions. If you have no light, you should jtag - either to original status or use Chancy's jtag file included in the kit and jtag directly to the converted 241. |
Gold Member Username: NydasPost Number: 7434 Registered: Jun-06 | Also read the last 5-6 posts in this thread: https://www.ecoustics.com/electronics/forum/home-video/436638.html |
New member Username: Borbar77Indio, Ca Usa Post Number: 3 Registered: Jan-08 | thank you very much for your help nalin and sorry about repost my message again |
