Pansat 2007a, can't reflash with factory bin. plwase help!
Username: Newpazzo
Calgary, Alberta Canada
hi
after installing bin 237, i lost the signal. it shows a message "No signal". a friend of mine said i have to refalsh with the factory bin. i have been trying to do so in the past two days. the problem is i keep getting an error message "updating failed" i think becasue i have B-75!!! .. please help.
thanks
Username: Dimwitt
Post Number: 378
Factory bin
Pansat 2700A_070313_B75_121_api_1.bin
With no signal message i would first make sure you connect from dish to IF INPUT not antenna in and your antenna setup is correct
Username: Newpazzo
thanks Tooter,
i tried to flash with the above bin , but no luck. my pansat was working fine, then all the sudden i lost the signal !!!
Username: Charjam
Post Number: 305
i would check the switch
Username: Newpazzo
i still got no signal.
Username: Newpazzo
is there anyway to test the signal. i want to make sure that the issue is due to software not hardware. how can i test for signal without using my reciever?!
Username: Newpazzo
what i have done so far, i flashed the reciever with b-75 boot then flashed it with bin 121 then falshed it with bin 240. still no signal !!!
