I have not used my Pansat clone for a few months and I have no idea which clone safe bin to upload into my box and I have also read about the b-75 upgrade I have this information regarding my Pansat
System info: SAFE API: 2.74 TiV0 Bootver: 6.2 27.Sep.2006
.... this is all the info i have and I believe my box is a 2700, So I would greatly appreciate some help.
I downloaded the Clone_2700_Upgrade_Package_v201(b-75)and followed the instructions but I still get Flash Update Fail... when I load Boot_2700A(b75)_(07)0310 into the receiver
Do you have null modem cable? If you do not know if the cable is null modem, than buy a DB9 M/F null adaptor. Then with the cable alone you have one type and with the adaptor and cable you have the other type of cable. Also make sure you unzip the files before using. Boot file is loaded with receiver on and Write clicked at the same time. The BINs are usually loaded clicking "write BIN" when "b" shows up.
