Frozen remote
Username: Bbford
Post Number: 11
why does the remote not work on view sat altra?
Username: Destine0429
Quebec Canada
Post Number: 414
You need to give them more info.
Has it ever worked? If so, how long? If not, maybe it's broken and you need a new one.
Did you check if they needed new batteries?
IF there are brand new batteries, and you know for a fact that the remote works, click on the STB button, then try to change the station. Sometimes, my daughter hits the Tv, AUX, DVD button and I have to click on the STB button and it works fine.
Username: Bbford
Post Number: 12
the stb button solved the problem its my budys viewsat he says thank you.
Quebec Canada
Post Number: 415
No Problem :D
