I downloaded DBPSW080117P-1 to the receiver and it is still not working. Is there another BIN that is working or do I need to set the receiver to default settings before loading it in?
it seems the latest bin worked on every body xtreme.
my scenario is they work on 110 and 119, but comes to 118, it is auto rolling, still try to find the answer.
in your case, after loaded always let it power off and sit another minute before turn on, so the auto roll will kick in. if this does not work, you will have to try to load the factory bin and latest bin again.
Just like mad said. I had to let my receiver autoroll longer than usual last night. Keep the bin file that you have because it works. I wouldn't load the factory bin unless you have to "last resort". As doing this you will lose all channels and have to rescan the sat's.
