Is that PANSAT3500SD bin problem?
Username: Howru2005
I am having pansat3500sd recevier and all the chanels was working fine with previous bin. All the chanels getting freeze Since I am using latest bin(01/17/08) ... folks is there any solution or just wait for another bin?
Username: Qwertyuu
Post Number: 34
install it again and everything will be fine
Username: Howru2005
installed so mmnay times but no luck
Username: Way2smart
Http://desifta.co.nr/
Post Number: 562
GO a factory bin then jan 17 bin u can find them at http://desifta.co.nr/
Username: Qwertyuu
Post Number: 37
Factory default
swich off the reciever (power)
Install new bin
Switch off again
tha keave it on autoroll for 4 minutes on channel # 150
Username: Way2smart
Post Number: 563
Do***
Username: Depalmaj
Wa. USA
Post Number: 69
jan 18 is the most recent go here http://www.future-fta.info/
Username: Howru2005
how do i get changel #150 ? I am not able to see channel #150
