More channels for 2700A possible?
Username: Nenads
Post Number: 12
I have been wondering this for a while now but always forget to ask. Is there a way to get more channels on my Pansat 2700A? I have the PPV and others but is there a way to get channels like Comedy Central or Spike I think or other channels like that. I get a few but was wondering if there is a way to get them all.
Username: Rtap
FL
Post Number: 1672
you can get all that with sat 110 and 119.whats your setup
Username: Nenads
Post Number: 13
I am pretty much a TOTAL NOOB when it comes to this. What do you mean?
Username: Yakovaki
Post Number: 187
if you are running dn you probably have 110 (ppv etc...)
if you want the other you need 119
these are directions that you need to aim ur dishes at
if you got someone to set it up...just ask them to add 119 for you
if you did on your own you can either add another lnb depending on what dish you have or add another dish for 119
aim it a more to the right from the 110 dish and you should be fine
if im talkin in another language than u have to do lots of reading on a good site (not like this one) try ftatalk dot com (regsiter and read)
good luck
