Pansat 2700a no quality
Username: Artista2000
Post Number: 8
I have a Pansat 2700a and don't get any quality at all when trying to scan a satellite. Is there a fix for this?
Username: Nydas
Post Number: 7235
There is new ECM on for DN. Wait for a fix.
What Boot and BIN do you have? Go into Menu/system and post exactly what you have there.
Post Number: 10
This what I have X.87BL API:75-2.15 EUbx Boot over :
75 29 Sept 2007
Username: Nydas
Post Number: 7239
This applies to GENUINE PANSAT 2700
You already have Boot 75 - You will see it scroll across when turn on the receiver. The BIN version is 215 - quite old.
If your Dish is pointing to BEV, you can load the BL87-237 BIN from
[link removed]
[link removed] for the loader and instructions.
If you are pointing to DN sats, you will not be able to get more than a few local channels on 110W and/or 119W.
Post Number: 11
Just loaded the latest bin 240 and still don't get quality in antenna set up, level is 99% ????
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1383
do a factory setup and then scan the satellite. check your antenna settings in menu change the TP or something..
Post Number: 12
Checked everything and no cigar. May have to call Pansat.
Username: Rtap
FL
Post Number: 1728
check your dish alignment.
list all your settings in antenna setup
