Captiveworks 800S setup
Username: Bluebee
Post Number: 42
I want to setup new captiveworks 800s but don't have the manual. I have downloaded the latest bin, did a blind scan, got channels but still getting scrambled channel. I am not sure if I am missing some steps. Can someone please provide a link with manual/instructions ?
Thanks.
Username: Kirankumar
Kenya
Post Number: 973
Blue,
seems like your settings might be messed up.
post your settings , dish type , lnb type and switch type if any so we can help
Username: Yoman
Post Number: 85
hey african..
Username: Bluebee
Post Number: 46
Thanks African.
LNB Type: Normal
DiSEqC: 3 (Signal strength goes to 0 on anyother switch #).
Signal Strength: 86%
While setting up Ariza 700, we have to go to Parental Control then i2004 to get to Key EMU to turn Keycode ON, I am wondering if something like that has to do in CW800S too.
Username: Brucester
Post Number: 1042
blue did inabble the patch if not hit f1 000 on the remote and let it roll on bev got ch 352 vu2 dish ch 195 110w 119w ch CNN this will help get 3 day epg and will roll faster on those ch hope this helps you you can go get the how to at crazyfta dot com
