Username: Sub33 Post Number: 2 Registered: Jan-08
Tuesday, January 15, 2008 - 04:58 GMT I powered off while up grading the reciever, no channels appear on the front panel.
Username: Tapeman New York City in-HD,
NY
Post Number: 2145 Registered: Oct-06
Tuesday, January 15, 2008 - 05:03 GMT So let me guess what's your receiver name? reflash receiver with more patience until it finishes process Also try remote to turn it on if neccessary
Username: Sub33 Post Number: 3 Registered: Jan-08
Tuesday, January 15, 2008 - 05:26 GMT viewsat ultra. I was using a usb plug to up grade my reciever. Accidenttly unplugged the power cord.
NY
Post Number: 2146 Registered: Oct-06
Tuesday, January 15, 2008 - 05:28 GMT Don't worry Just go thru loading process once again
Username: Kirankumar Kenya
Post Number: 951 Registered: Oct-07
Tuesday, January 15, 2008 - 05:54 GMT chash, if you could post the result it will help others
Username: Rtf Canada
Post Number: 30 Registered: Aug-07
Tuesday, January 15, 2008 - 11:36 GMT Only problem is that you probably won't be able to use the USB stick. Use the 9 pin port and and VS Loader program to load. Been there done that it will work.
Username: Sub33 Post Number: 4 Registered: Jan-08
Tuesday, January 15, 2008 - 15:26 GMT can't get into menu receiver not responding
Post Number: 953 Registered: Oct-07
Tuesday, January 15, 2008 - 15:30 GMT chase, did you try using a cable instedd of usb stick?
Username: Jayson Post Number: 74 Registered: Aug-06
Tuesday, January 15, 2008 - 15:31 GMT chash do what Richard told you to do........
NY
Post Number: 2148 Registered: Oct-06
Tuesday, January 15, 2008 - 15:44 GMT Yep If your device didn't come with null cable yo need to buy a 9 pin module off e-bay If it did come with 9 pin module Yo need a program called loader-2 with receiver off Yo open loader-2 from a laptop computer via null cable turn back on from switch and it will start loading update bin Yo use same bin, plus loader-2 plus 9 pin null cable
Username: Sub33 Post Number: 5 Registered: Jan-08
Tuesday, January 15, 2008 - 15:56 GMT will some one help me whith my viewsat ultra
Username: Jayson Post Number: 75 Registered: Aug-06
Tuesday, January 15, 2008 - 15:58 GMT ????????? Did you read previous posts???????
Username: Sub33 Post Number: 6 Registered: Jan-08
Tuesday, January 15, 2008 - 16:13 GMT do i need laptop computer to do this. and ware do i getloader-2 from
NY
Post Number: 2151 Registered: Oct-06
Tuesday, January 15, 2008 - 16:17 GMT Any computer that has 9 pin male plug to male plug of your receiver Your null cable has to be female to female Loader-2 can be found at dsstester (no registration) or thetotalfta or ftabins or ftatalk Yo can also try dsscentral-net (no registration) Use at your risk
Username: Sub33 Post Number: 7 Registered: Jan-08
Tuesday, January 15, 2008 - 16:28 GMT i'll just go out and buy a new one. F.it
Username: Sub33 Post Number: 8 Registered: Jan-08
Tuesday, January 15, 2008 - 17:34 GMT i got 4 lines in front panel.no #
Username: Sub33 Post Number: 9 Registered: Jan-08
Tuesday, January 15, 2008 - 17:45 GMT i got 4 lines on front panel no # come on rich ard help me
Username: Lol Post Number: 222 Registered: Sep-06
Tuesday, January 15, 2008 - 17:50 GMT Put it back in the box and return it your not bright enuff to own a FTA reciever
NY
Post Number: 2152 Registered: Oct-06
Tuesday, January 15, 2008 - 17:56 GMT It is not that hard Yo'll be up and runing in less than 10 minutes 3 simple steps Did yo get a null cable with the unit?
Username: Sub33 Post Number: 10 Registered: Jan-08
Tuesday, January 15, 2008 - 18:13 GMT yes igot null cabie with the unit
NY
Post Number: 2154 Registered: Oct-06
Tuesday, January 15, 2008 - 18:22 GMT Then yo ready to go Step-1 Download Loader-2 PGM and unzip it along with 081226 bin Step-2 Connect a computer with 9 pin plug via null cable to back of receiver turn off receiver from back switch Step-3 Double click on Loader2 select pc tp STB select bin 081226 turn on stb let it do its thing unintrrupted Yo should be set to do business
Username: Sub33 Post Number: 11 Registered: Jan-08
Wednesday, January 16, 2008 - 02:43 GMT thank u king tapeman it's ready to go
Username: Fdelmar Post Number: 2 Registered: Dec-07
Wednesday, January 16, 2008 - 05:31 GMT will some one help me.im new here.i have fortec star lifetime ultra reciver.which loader i need to.i have laptop comp whith window xp. thaks.........
