hi i have a vw golf 4motion i upgraded my system about 6 months ago and its beeen spot on i have clarion 12 cd changer kicker sub 2 amps cant remeber there name had 2 new front speakers and tweaters put in and a parcel shelf full of components and speakers suddenly my front right speaker started makin this clicking noise and all audio dips and way 2 much base comes on then clickin wud come back then nothing but clickin from the front right speaker i disconnected my sub still clicking disconnected parcel shelf still clicking only front speaker on still clicking i oput it all back 2gether and now i had just bass and no audio anyone have any ideas thanks mike
Wow. We'll I kind of understand what your saying, then I don't. But I'll ask some question then you just say thats what your trying to say or w/e. Anyways.
So your say that your front left was making some weird noises similiar to distortion? Then you disconnected your rca's going to the sub amplifier and the noise was still present? and then you uninstalled everything, then reinstalled everything and you still get some distortion? Is this distortion coming from all over such as your subwoofers, and front speakers? There could be a couple of things. 1. Your headunit is bad. 2. Your rca's are bad, could of been spliced open. 3. Your amplifiers are gone. To test this, use a home receiver, send the rca out of the reciever into your car amplifer, turn on your car to get the amps running. Play something, if there is no noise, then it is your headunit. If that does not work go to test number 2. Change out your rca's since they are very cheap to replace. Use to cheap ones to connect from your HU directly to your amplifer. Don't try to make it pretty just run it straight across the seats and such. If that doesn't work go to test number 3: Swap out your amp for another one and see if any of the noises go away. Also, make sure your settings on your headunit are correct as well as your amplifiers. Sub amps are set to LPF around 80hz. Speaker amps are set at HPF around 80-120hz depending on your listening habits. Now correct me if I'm wrong, since I'm trying to understand where you are coming from.
thx 4 the reply im very confused at were my system is at i changed the fuses in both my amps and i was out in it b 4 and the crackling stopped and it just splurted out bass with no audio voice over lyrics so i was bored and pretended i was a rapper so started 2 make my own music up to the bass i then after about 30 mins i heard vocals again so i tried it again and its fine but i doubt it will stay consistent is it a used head unit and 12 cd changed so the hu may be faulty but thanks for the advice and if it happens again i will let u know but if it does i will try everything u said or well i take it to the audio electricians coz im not the best to be playing with electrics thanks again berny mac u was great in friday 2
its come back again i know ive got a faulty connection some were as the music came back fine not long ago and now its gone back 2 clicking and slight audio in speakers with 2 much bass but i cant get head unit out 2 check connections at the back of it
