Just out of interest Yukon how does the SM24 work ? I know you can install tone switches (22kHz) after a diseqc switch but I don't get it for your config. Does the SM24 work on 13/18V and 0/22kHz ?
SM24 2x4 Multi-Switch is Non-powered Up to 4 satellite receivers can independently select different satellite channels, Works with C / KU band, DSS, FTA, DVB, and HDTV.
