**A little help please**
Username: Alpine97
Paramount, California USA
Post Number: 176
Ok Chauncey, we can probably make a deal.
I bought these subs off my friend and he doesnt know what ohm they are or if they are DVC..
Can any of you or (Chauncey) identify what these infinitys are? I know they are Kappa Perfects 12.1d 350 rms 1400 peak...But it doesnt say what ohm they are or if they are DVC...
I would have to email you the pics because this host will not support 600x600 and my software wont shrink the pics...
Username: Nyyfan13
Fi SSD USA
Post Number: 7902
http://shrinkpictures.com/
Username: Alpine97
Post Number: 177
Thanks Yanks for that image host site...
well here they are..
Username: Alpine97
Post Number: 178
Username: B3n07
Louisville, Ky USA
Post Number: 677
whats the cone say usurally infinity says dvq or vq but im a say there dual bc they have 4 post
Username: Nd4spd18
Northwest PA
Post Number: 5424
Well they are obviously DVC since there's 2 sets of terminals on them
To find out what impednace (ohms) they are take that wire off of the terminals. Set a DMM to read ohms and put the probes on the terminals..........
Username: Nd4spd18
Northwest PA
Post Number: 5425
Actually never mind that. If I remember correctly, those only came in 4 ohm.
So the ones you have must be DVC 4 ohm.
Username: Alpine97
Post Number: 180
These are the older ones and they just say infinity on the front...
This is how they are wired now (as I bought them)...
both subs are : (-) connected to (-)
(+) connected to (+)
then on one side of the terminals there is another (+) and (-) running to the box terminal...Thats how both subs are...
Then there is a wire on the back of the box that connects a (-) to a (+) making it where two wires, (0) and (-) are running to the amp
Username: Alpine97
Post Number: 182
I called Infinitysystems.com and talked the customer suppoert...they are dual 4 ohm....for now...haha
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13564
dvq kappa perfects dvc4ohms
Username: Nd4spd18
Northwest PA
Post Number: 5434
Didn't I just say that 4 posts ago
Post Number: 13565
u did, but i dont think no body believed u.lol
Username: Alpine97
Post Number: 183
"If I REMEMBER correctly"
Sorry, just need reassurance...
Username: Alpine97
Post Number: 184
Just got the kappas all hooked up with the new amp. 1600 brutis... it bangs a lot HARDER!!! They dont even distort with the gain all the way up...
How should I set my settings tho...I know 0 Bass Boost...but everyth9ing else ???
Post Number: 13566
"They dont even distort with the gain all the way up..."
Dont do that..
Username: Alpine97
Post Number: 186
No I dont have the gain turned up all the way... I have it about 3/4 on the bass knob..
Username: Skibum12189
Cleveland
Post Number: 2437
bad
" I have it about 3/4 on the bass knob.."
did you set the gain with a dmm? by the way hifonics "bass knobs" are actually gain/bass boost knobs, unhook it now if you know what's good for you. I blew a sub that way on my old 1206d
Username: B3n07
Louisville, Ky USA
Post Number: 680
nick s will you listen to the people on here they will save you money time and your products
1. what size box you got for thm kappas to small could make them choke or sound different
2. how do you have these subs hooked do you have them wired down to 2ohms or are you running both subs at dual 4 ohms?
3. how did you set the gain di you use te gain set tools nd use the dmm to set it?
4. this is the best advice to you and anyone ofyour friends DONT USE BASS KNOBS they do abustley nothing unplugg them take it lay it in the middle ofyour street and run it over
Username: Alpine97
Post Number: 195
Ok...Well I called a customer rep from www.infinitysystems.com and he said that I need 1.75ft for each sub so I got a 3.5 ported tuned box at 35hz.
2. They are dual 4 ohm wired down to 1 ohm
3. I just used a flat head screw driver to set the gain...whats a dmm and how do you use it.
4. I will unhook the bass know tomorrow
5. Thanks..
Username: Alpine97
Post Number: 197
I'm confused about the who gain thing...some say to use a dmm at 50hz and some say tune it by ear. I have always done it the way Govmint cheese has done it, by ear...but I didn't know that about the boost knob....thanks...saved me money
Username: Alpine97
Post Number: 198
My subs are bangin' right now tho...I just want to keep it that way
Post Number: 13575
"My subs are bangin' right now tho...I just want to keep it that way"
yeah but at what cost??? Clipping??
http://mobile.jlaudio.com/support_pages.php?page_id=143
Username: Alpine97
Post Number: 200
No I dont want to clip them...i am going to disconnect that knob tomorrow...
Username: Alpine97
Post Number: 201
Thanks Chauncey....it looks like I need to download that frequency and burn it on a cd...I don't have a volt meter tho...btw...can you get ahold of any L5 12"s chauncey?? If so, do you still want the Kappas?
Username: Jtown
Team Revolution, Texas
Post Number: 1683
you can find a basic DMM(digital multimeter) at any dept store and I think even walmart for $15, ROE has free test tones that are not attentuated.
when you set the gain, you need to set the DMM to measure AC voltage
subwoofertools has a voltage calculator that will tell you what your desired voltage output from the amp should be. or you could follow what zac davis sugg and just set the amp the same as the preouts on the HU ie 3/4/5 volt, etc.
Post Number: 13582
i cant get any L5's and u shouldnt want them..they sux...and yes i still want the kappas, just say the word and we can work something out..
Username: Alpine97
Post Number: 205
Ok Chauncey, they are your man..this one guy wants them around here and he offered 140 for them in the sealed box....I told him they are sold though...How much are you willing to pay?
Oh yeah, made a smart mover today and took back that Hifonics 1,600...got a pretty much brand new Memphis ST100D for 100 less than the Hifonics..lol...I also got two type R's in a huge ported box from the pawn shop...I dont know how big it is but I'm sure its going to bang!
Username: Alpine97
Post Number: 206
St1000D----^
