Saz 1500 ?'s
Username: Mendonmafia
Post Number: 667
will this thing really put down 2000rms @ 1 ohm on 12 volts? is it really .5 ohm stable?
Post Number: 668
.5ohm stable daily is what i meant. i know it can do it for short times. also what kind of power should i expect @ .5 ohms on 13.8 volts?
Post Number: 672
i know some of you guys have used this amp
Username: Nd4spd18
Northwest PA
Post Number: 5491
They are .5 ohm stable if you've got the proper electrical system (BIG HO alternator and battery)
IDK how much power they do at .5
Username: Jtown
Team Revolution, Texas
Post Number: 1714
M.S. didn't they stop offering a warranty for .5 ohm, cause people didn't have the proper charging?
Username: 420alldaylong
Post Number: 3188
My bro run my Sundown SAZ-1500D at .5ohm on a pair of RE SX 10" for almost three months with no problems at all.
Username: Drant19
DUB-C, TX
Post Number: 197
i think they only stopped warranting the saz100D because people were droppin that amp to .5ohm but i could be wrong.
Username: Nd4spd18
Northwest PA
Post Number: 5497
They discontinued the warranty if the amp is run at .5 ohm because dumbazz people were running them at .5 on stock charging systems and blowing them
Post Number: 3189
My bro had a HO alt. and Kinetik under the hood and 0gauge through out the ride.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1171
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7556
