Username: Cover_point Post Number: 3 Registered: Jan-08
Monday, January 14, 2008 - 18:41 GMT Hi all, I have 119W but still cannot get channel 576 to watch cricket. I did a power scan. What else do I need to do? any ideas? Thanks
Username: Kirankumar Kenya
Post Number: 932 Registered: Oct-07
Monday, January 14, 2008 - 18:46 GMT do you have 61.5 ? if you do then you should get it there
Username: Cover_point Post Number: 4 Registered: Jan-08
Monday, January 14, 2008 - 18:51 GMT African, I don't have 61.5, but channel 576 is said to be available in 119 too.
Post Number: 933 Registered: Oct-07
Monday, January 14, 2008 - 18:53 GMT it is have you tried to scan ? what box do you have?
Username: Viruscauser Leesburg,
Georgia
Post Number: 735 Registered: Mar-07
Monday, January 14, 2008 - 18:59 GMT ZEESA also on Echo7 TP 12516V
Post Number: 935 Registered: Oct-07
Monday, January 14, 2008 - 19:00 GMT right , but we need to know why he is not getting it so we can help him out
Georgia
Post Number: 736 Registered: Mar-07
Monday, January 14, 2008 - 19:17 GMT If the blind scan is not picking up the TP, maybe entering the TP manually and then scanning it would help. Worth a try.
Post Number: 939 Registered: Oct-07
Monday, January 14, 2008 - 19:27 GMT I guess he doesn't need our help ,probably left the forum
Username: Cover_point Post Number: 5 Registered: Jan-08
Tuesday, January 15, 2008 - 17:10 GMT African/Abby, Sorry was a bit busy. I have a Pansat 2500 clone converted to 2700. I will try by using the BIN specified by Nalin and then do a Blind scan. Thanks for the help. Will also try entering the transponder manually.
