JK or anyone with a ford taurus
Username: Insearchofbass
Post Number: 7527
have ou teste the results using one 12 vs two im trying to figure out if its worth getting a second 12 since I have some store credit
Post Number: 7528
nevermind I made up my mind im only running one 12
Username: Jkidder
Gunshine , State Flawda
Post Number: 3043
its not fair for me to even answer. i had one 12 on 1250 watts and then 2 12's on 5k.....
Post Number: 7529
what kind of spl increase did you get using two 12's over one even with the power diference
Username: Th3pwn3r
Post Number:...
Post Number: 6498
JK how come we have seen pictures of some of your equipment but we have never seen any of it installed?
Username: Jkidder
Post Number: 3046
because it's not all installed and i don't have all the wiring set out.
Username: Th3pwn3r
Post Number:...
Post Number: 6505
Ahhh so I guess you can't answer the question that Sean asked.
Username: Jkidder
Post Number: 3047
i guess your solid at guessing
Username: Jkidder
Post Number: 3048
Post Number: 7538
I guess the only way I will know is try one of my other 12's in with it and meter it....its a different brand but it will give me an idea
IM THE REAL SLIM SHADY
Post Number: 16844
alot of guessing going on here. lol.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5081
i want some gueso chiz
Post Number: 7539
I should just buy the second re12 and be done with it........if nothing else I can have one in reserve if I dont run two
Post Number: 16849
i guess that'll work sean.
Post Number: 7540
im guessing thats not nice driving haha
Post Number: 7541
looks like some people have made those re 12's pretty loud on low power looking at ROE
Post Number: 5083
you got aim sean?
Post Number: 7542
yeah hold on let me log on sean50077
Post Number: 16851
sean if you want some low powered re subs that sounds awesome and loud, try the re sr. i've heard a van with 16 12s in a wall and it was the cleanest thing i've heard in a wall.
