Found an Audiopipe AP-30001D for decently cheap...not really looking to USE it, just sell. was wondering how they do performance-wise just for kicks...??? Thanks.
Never used any of their amplifiers (didn't even know they made amps actually), but I've had nothing but bad experience with their installation accessories.
haha damn M.S on the other hand, i've had very good luck with their installation accesories. I've used 4awg wires and 80A fuses in small installations, no prob at all :D
There's only one audiopipe amp i'd use, it shares the same board of the RE 1200.1, obviously the components aren't the same i think, but the internals are exactly the same. It does 1000w rms at 1 ohm.
I've used quite a few accessories from Audiopipe and they were great. The ANL fuse holder that I had from them was built to be a beast and would probably take a hit from a hammer and not shatter. I can't say much about their amps but for the money they make some decent subs. As far as their terminals for batts go I can't say much as I've never used them. However... I did have some from Knukonceptz and they didn't even clamp down on the terminals properly, in short, they sucked. Lots of companies have good and bad products out there you just have to see what they have that's good and what isn't.
